Yep understand ... control head fully open (or TRV) and adjust via lockshield ........... will have another go when I change the rad
What temperature differential are you trying to achieve and how are you measuring it?index rad takes an age to get warm, even with lockshields down to only 1/4 turn on all other rads .... it does get hot .. but only after all the others ... and as this is in the lounge - not ideal, can be 1/2 Hr or more before it gets hot. Variable head pump is on max speed - so can't increase flow rate ........
Yes, I know what you measure; I'm more interested in what temperature you are using (11C) and how you are measuring it.It is the temp difference across flow & return for each rad that you set ... 11 degree is the typical design range.
Not sure about the relevance of that.It would probably be safe to assume little or no design rules were used.
Don't know how I missed that.As mentioned I will be measuring with pipe thermometers ...
