I'm looking to replace an existing Electro Mechanical Sangamo Solar Dial timer with an electronic timer i bought from RS-Components (505-9833, MLU2 7 day 1 channel digital timer).
The existing timer has Live and Neutral (Red and Black) wires going in and Live and Neutral (Red and Black) coming out. There is also the usual Green/Yellow earth going into the Existing Timer.
The connections for the new RS timer are as follows:
1 & 2 are shown going to a timer symbol, which i assume will be straight forward (1 = Live (Red) and 2 = Neutral (Black)).
My main question is to do with the outputs which are 6, 7 & 8. 7 appears to be the Common which is shown as the switching arm to 6 with no connection to terminal 8. Anyone help me out with to where the existing outgoing Live and Neutral wires from old sangamo timer should go on the new RS timer? I'm assuming 7 is the common therefore also assuming 6 is normally open and 8 normally closed?
Cheers View media item 26341 View media item 26341
