Hi All,
Been lurking for a few days and having a little mooch about the forums and decided to register and post for comments and advice.
I've looked around various forums and this seems the most varied and also the most sensible and the place where I am least likely to get shot for asking questions about a DIY rewire.
Now this is going to be a relatively long post so my apologies in advance but I hope there are a few people around who manage to make it to the end and provide any comments or advice they see fit - both positive and negative.
My Dad has just bought a relatively small house which is need of gutting and a complete refurb. In order to save some money I will be doing various things for him, one of which is the rewire and replacement of the consumer unit.
I'd also like to clear one thing up from the beginning. The entire refurb, including the rewire and Consumer Unit replacement will be notified to the LABC. In fact, he may already have sent the forms off this week. He is dealing with the notification and any associated paperwork, I am simply doing various jobs that I know I can do. I'm posing this rather lengthy post to see what opinions, comments and advice people have in order to avoid any mistakes which would require rectification prior to approval by the council.
Now, to the point of the post. Basically, the entire house will be rewired. The house consists of a living room, a kitchen / dining room, stairs and small landing and two decent sized bedrooms. Oh, there's a bathroom too obviously!
I'm going to leave the existing installation in for the time being so there is power to the house until "switchover day". The existing CU is of the removable rewirable fuse type with 6 ways. The installation is not RCD protected in any way. There is also an electric shower in the bathroom. Now I may be wrong but I though any electric shower had to be RCD protected. If I'm correct then I have no idea when this reg was introduced but this is a fairly recent looking shower installation (within last four years or so I'd say).
So anyway, I'm planning on fitting a MK 12 way Dual RCD CU which should provide plenty of capacity for future extension. It will have a 100A main switch with a 80a and 63a RCD's.
I'm planning separate circuits for:
32a 2.5mm Kitchen ring (& an IP56 outdoor socket)
16a 2.5mm Radial for appliances (but thinking a 32a ring would be more sensible)
32a 2.5mm Living Room ring (basically a downstairs circuit minus the kitchen / dining room)
32a 2.5mm Upstairs ring
6a 1mm Downstairs Lights
6a 1mm Upstairs Lights
40a 10mm Shower
Consumer Unit will be located in the living room and the cables for the downstairs circuits will be taken straight down into the crawl space and then will rise to each outlet, buried in plaster. Cables for the upstairs circuit, both lighting circuits and the shower will go straight up the wall from the CU, buried in plaster, and will then go around the house in the void between ceiling and floor (except the upstairs light circuit which will obviously continue up in to the loft).
Am I right in thinking that I am allowed to run the cables straight up the wall in the safe zone that is 150mm from the corner? I was thinking about boxing the cables in anyway with plasterboard rather than burying in bonding for future access. The consumer unit will be located in this corner too so does the safe zone extend to the area vertically above the consumer unit? However, the CU will be in a cupboard so it may not be immediately apparent that this is a safe zone.
Now the upstairs and downstairs rings and lights are straightforward. There will be a relatively large number of sockets on each ring to provide greater flexibility in the future but this isn't an issue as far as I'm aware.
As far as the kitchen ring goes, this again is straightforward with the exception of the outside socket. The entire installation will be RCD protected but are there any other issues I need to be aware of when it comes to installing an outside socket? The cable feeding the socket will basically come straight through the wall from behind the IP5 socket. There will be a switched FCU inside which will allow the power to the outside socket to be cut when my Dad goes away and stuff.
For the shower, is a 40a MCB and 10mm cable over a run of not more than 15m sufficient for a 10kw shower? The shower cable will be clipped direct to the inside of an external wall for about 2.5m and either buried in plaster or covered by plasterboard in a small 1" cavity. From there it will be in the void between ceiling and floor before it rises in the all to an isolator switch outside the bathroom. It will then rise again from the isolator switch to the loft, across the loft a little and then down the wall to the shower. This time, where the cable is in the wall by the bathroom it will be clipped and buried in bonding. Is there any need to enclose it in capping other than for ease of access in the future? Maybe a 45a MCB would be better as based upon a 240v supply 10kw is rated at 41a and based on a 230v supply slightly higher at 43a or thereabouts.
In terms of the layout for the CU, I was thinking of having the downstairs ring and the kitchen ring on the 63a RCD, the upstairs ring and the shower on the 80a RCD, the lights on their own 6a RCBO's and the Appliance radial or ring on it's own 16a or 32a RCBO too. Thinking about it, maybe I'd be better off putting the outside socket on the appliance radial / ring.
My Dad also wants provision for a supply out to the shed a the end of the garden. I'm not too sure about how to go about this just yet so will need to research some more. I know I'll need SWA cable and it needs to be buried a certain distance below ground but I don't know much about connecting it to one of the circuits or if this is even allowed.
Oh, another thing, I was thinking of fitting an emergency light on the stairs. Does this seem a bit overkill? I just figure it's prudent and may as well be done while the whole install is being done. Any recommendations as to a non too ugly, reasonably priced emergency light? Also, what's the difference between maintained and non-maintained (I know the clue is in the name lol but what maintenance is required?)
Oh yeah, another question . Sorry. When I'm running cables under the ground floor I was just planning on clipping them along the underside of the joists. What do I do though when clipping them across joists? I know cable trays would be preferable but they're expensive and I also can't be bothered with the hassle of fitting them if they're not entirely necessary. Can I just clip to on joist, run cable to the next with a small amount of slack and then clip to the next?
For running the cables under the floor upstairs I'm going to drill the joists (and forget about any notching that already exists - I won't be re-using notching) where cables need to pass across joists. I know there are regs regarding drilling joists so I'll need to refresh myself on them but I recall that holes must be a minimum of 50mm from the surface of the joist and must also be a certain distance from the end of the joist and also a certain distance from other holes. I don't think the hole diameter can exceed a certain percentage of the depth of the joist either. I won't be using one hole for all cables - the most will be one 10mm cable through a 16mm hole or one 2.5mm cable and one 1mm cable through a 10mm hole. Is that acceptable?
I think that's it for now. I'm sure there'll be other questions but I'll post if I think of any others.
Oh yes, there is another one. Building regs state sockets must be no lower than 450mm off the floor and light switches no higher than 1200mm of the floor. Now as this is a complete refurb I assume these regs apply to my Dad? He's not too happy about having them at this height but regs are regs and if they apply then it won't be signed off unless the installation complies. A daft question on this though. For sockets, is it the BOTTOM of the socket that can't be lower than 450mm and for switches is it the TOP of the switch that can't be higher than 1200mm.
And another point! I obviously don't own the equipment to test the installation. From what I can make out, the council don't go as far as testing the installation, they only ensure it complies with the regs. Once installed, would getting a PIR done be a good idea?
Ahh, and another, bonding. From what I can make out on the regs, main and equipotential bonding isn't necessary now. However, is it still worthwhile? Gas box is within a couple of feet of the CU anyway and it's no hassle to run a cable to the water stopcock. Would it be 10mm earth cable I'd need to use?
Right, that really is it for now. Apologies for the mega long post and thanks in advance for taking the time to read this assuming you managed to stay awake and got this far.
SkyVanMan
P.S. Not sure if the supply is TN-s or TNC-s but I know it's definitely not a TT supply. Any pointers on how to determine the type of supply?
40a 10mm Shower
SkyVanMan
