need to rewire my downstairs ring main, bit confused at the new rules and regs some help would be much appreciated on the following points.
1 when refitting sockets and backboxes do they have to be at the new hight of 450mm or can they stay at existing height?
2 when routing new t&e do the joists have to be drilled/notched or can i just use cable clip them to the joists?
3 i also belive you can no longer plaster over cables you have to put them inside trunking. is this correct?
4 also looking at changing cu for a split load type to be able to run fridge/freezer on seperate circuit this will be a radial circuit will 2.5mm t&e be sufficiant ?
any help would be most helpful, thanks
