have had a couple of quotes for boilers worcester bosch 30si or 34cdi understand the gas pipe will need to be changed for the 34cdi model is the only difference the litres per mjnute.not asking would you buy one or asking for an alternative model
High flow rates are only useful if you ar a bather not a showered. Large combis rarely supply more than one hot tap properly at a time unless you have flow regulators on each and every outlet.
