J
jonny7913
i make fastneat right on everything said
garyo said:what percentage of conservatories are actually built with vertical DPCs?
I'm just about at the point where I've just about finished my dwarf wall, and I wasn't aware of this either!
I have a victorian solid wall, so I assume my bricks are less porous than some... should I fit one? How deep into the wall does the DPC go?
Richard: How were you told to fit a DPC? I assume you're talking about cutting a vertical slot with an angle griinder and pointing in a normal DPC?
Cheers
Gary
no gary,inbetween brick work and block work,drop a 150 damp against inside of brick flush with top then lay your block flat against the inner side of brickwork bridge the cavity
richard.jones13 said:So from what you are saying there is no need to for a vertical DPM where the new brickwork joins the house or where the frame joins the house?
