consumer unit
Always makes me chuckle when you see this, nice wood board stood off the wall to mount the cu on & some twonk uses a hatchet & chops the bottom out of the cu housing for entry of the tails.
Why not take the tails behind the board & enter the cu from above or through the back, it doesnt take that much longer.
Personally I find a 25mm hole saw is a nice fit for 2no. 25mm² double insulated tails, and 1no. 16.0mm² single insulated earth.
Drilled in the bottom left corner of this board.
At the risk of sounding like a brown-noser :oops: I must say that CU is very neat & tidy RF. I guess that you took the Supply cables straight out of the back of the unit, behind the mounting board ?
So that is OK then ? I'm glad about that because it's what I would like to do.
