Whilst the CM907 is a good item for an owner occupier, I would never recommend it for anywhere where tenants have access to it as its far too complicated for most homeowners let alone tenants who seem to have zero ability to deal with anything more complicated that a light switch.
I also came across the TPI models which might be good for the ground floor as that is on more often.
So i might get one of each or both CM31 (analogue ones)
The Honeywell CM907 is something i will keep in mind
There are many well-educated, intelligent people who have decided to rent a property rather than buy one, frequently because they have not been able to save up the 20% deposit now required by most lenders. In central London that can easily amount to £60K or more.
As for being 'complicated', maybe you should spend more time explaining it to the tenant/customer.
