Since moving my consumer unit my cooker radial cable wont reach. Can I join it in the loft to new length and then get electrician to test and connect?
Who'd like to offer odds on the various possible reasons why not?Why didn't the electrician who moved the consumer unit extend ( or better replace ) the cable from the cooker when he (or she ) moved the consumer unit.
If a join is inevitable and crimping/soldering are not options, then (provided it will remain 'accessible') the best bet would probably be something like (click here) , namely:It's common enough to join cables, sometimes you have no choice. But what type of junction box were you planning to use? It's unlikely a regular 30 amp one would do, as very often cooker cable is too big for the terminals.
Maybe (just as many things we see here are 'a tad alarming'), but I'm far from convinced that the situation is quite as you appear to suspect. Someone who is asking whether he needs to get an electrician to 'test and connect' an extension to one circuit is, I would have thought, very unlikely to have moved the CU himself without involvement of an electrician (unless, perhaps, we're talking about a trivial degree of physical 'moving' of the CU).But it is a tad alarming that someone who moves a CU then asks "Can I join it in the loft to new length and then get electrician to test and connect?"
Thanks for clarifying - as I implied in my last post, I suspected that the situation was probably something like that (some people tend to 'assume the worst'; I tend to 'assume the best'{innocent until proved guilty}!!).Thanks all ... When the consumer unit was moved to new location (by a qualified electrician) a year ago I had a gas cooker and didnt envisage needing the cooker circuit and so, as it was too short, decided to leave it unconnected in the loft.
That rather depends upon who is going to do it. If an electrician, you should leave the choice to him/her. If you're planning to do it yourself, then a big junction box, just as I depicted, would probably be the best - provided it remains 'accessible for inspection' that would be fine - there is no requirement for 'routine inspection'.The join would be in the loft, clear of any insulation etc, but would not routinely be inspected. As for deciding what type of connection is most appropriate I would be glad of your suggestions...
It's not necessarily as simple as that, so I suggests you discuss the matter with the electrician of your choice before you do any work. The person who notifies the work has to declare that they have been responsible for all the design, installation and testing.Thanks John this is very helpful..
What I would like to do is join in the loft and then get electrician to connect and test at the CU and notify LA.. I see this as a cost-effective solution rather than, as I suspect would be a likely outcome, an electrician preferring to run a complete new service which would spoil decorations and cost considerable more than the cost of the cooker...
I tend to assume people mean what they write.I tend to 'assume the best'{innocent until proved guilty}!!).
