Okay to cut a long story short, i wanted to recess a wall mounted electric fire into chimney breast as glass screen could cause my kids some serious damage. Only want to use flame effect, no heat. I cut a test hole out with a plasterboard knife as it was only soft "thermalite" block. Cut into a copper pipe. Not sure what pipe was for so called out of hours emergency number. Gas man said not gas. Plumber said not water, "its a copper lintel due to modernization" (This would explain why the plaster was always cracking). Its a 1950's house 1 tenant from new, had new central heating, wiring, bathroom and kitchen fitted in february 2011 just before we moved in. Alarm bells started to ring, whats this "copper lintel" supporting? and more importantly what have they taken out to get it in? So i removed the surrounding plaster and this is what i found.The throat lintel has a bearing of over 150mm on the left hand side and only 40mm on the right hand side. Am i right in saying that it should have a minimum of 100mm bearing on the right hand side? Do i now need permission to add brickwork below as its structural? Surely a "copper lintel" is against the regulations. How do i prop the throat lintel without destroying it whilst bricking up for the support? Should i really be expected to pay the call out charge for something that shouldn't of been there?
