There is a description here: http://www.thewindowman.co.uk/wood_drainage_files/wooden_windows_drainage_new.pdf
I have used a method similar to that described but have found it easier to fix the glazing tape to the glazing unit first rather than to the frame and beading. I also didn’t bother with the drainage holes but did add drainage/vent slots to the bottom bead.
