When I did our coving on new plaster, I marked a pencil line where the low edge would be, then using a small cross-pein hammer, made indents in the plaster to give the adhesive a better key. They added small round nails along the line, to give the coving support until it set up. Rather than adhesive, I used Thistle - because I had some and yes, I misted.
