- Joined
- 17 Feb 2019
- Messages
- 202
- Reaction score
- 13
- Country
Hi all,
See the attached images below, as part of some renovations, I wanted to do a couple indian stone curved steps leading up to the front door.
Have had a pop but due to the curve, it's been cut appropriately and meant the cuts for the top facing pieces have ended up being exposed and visible.
Is there a method that people use to blend those cuts in or to smooth them off somehow so there's less contrast? my concern is equally about the colour as well as the difference in texture, will the cuts always be a bit lighter than the rest of the stone and look odd? and is there a way to resolve that?
Alternatively, could I lay it out a different way to avoid this, i.e - Rather than having the top facing pieces overlapping the front facing pieces, could I have the front facing pieces taller, so the top of them is flush with the top of the top facing pieces and cut the top facing pieces back a bit and have a mortar joint between where they meet, if that makes sense? Or is that method just a big no-no when it comes to laying stone?
Lastly - This is how I wanted it to look ideally, seems alot smoother, assume theyve done this using a circle pack instead? dont think that'd work in my case as ours is a much smaller angle of curve?
