finding and eradicating the source of damp is complicated.
walls can take months to dry out.
once walls start to effloresce, this will continue to come through any decorated finish. if the source of damp is removed the wall will draw moisture from the air and continue to effloresce indefinitely.
the only way to deal with it is as i've described earlier.
if the wall is subject to water pressure from outside it will need to have a silicon dpc injected as well as a possible dpm and floor screed.
if the wall is well below ground level it will need a special insulated membrane to counter the effects of condensation, and then dry lined. we have carried out this type of work on the seafront where some businesses are situated under the road, fronting onto the beach, formerly used by fishermen for storage
it is of little value waiting months or years for a wall to dry out, when u want to decorate and live in it.
getting back to madsey, who posted for a bit of practical advice which i gave him and in a cost effective way.
i am not looking to score points here over people, just offer a bit of advice which i hope is helpful.
how much practical advice to madsey has actually been offered to give a solution to madsey's problem with his damp wall?
masona, u haven't said what you would do to sort it, and how will you deal with the efflorescence.
also, the wall is probably 225mm thick, i would be surprised if it were only 100mm.
have you ever done work to rooms supposedly damp- proofed 6 months ago and then the efflorescence starts coming back through and the 'builder' does a vanishing act leaving the client needin it all totally re-done properly with a vandex type membrane put in?
yes.
have u ever had comeback from the said client?
no.
