I put the handrail up over a year ago and when I bolted the posts to the joist I did them up so tight the head just started to pull through the joists.
18 month on the the nuts on the bolts have come loose, but I obviosuly can't tighten the nut / bolt any more otherwise the head of the bolt will continue to pull through the joist. I used square washers on the nut end was I being a numpty for not using these on the bolt head?
