Detecting current in twin plus earth
Discussion in 'Electrics UK' started by Blitherer, 30 Jul 2011.
  1. Blitherer
    16 Dec 2008
    42
    Thanks Received:
    Dorset
    Country:
    I realise that one can use a current clamp meter to measure current in a single conductor, but is there anyway to measure current in twin plus earth without disconnecting it or cutting it?
    M.
  2. fireman22
    18 Mar 2005
    796
    Thanks Received:
    10
    Country:
    well if you loosen the accesory box you can use a mini clamp meter and clip it around one of the live conductors, i have done this to test immersion heaters inside the switched spur, otherwise outside say a twin & earth the answer is no
  3. holmslaw
    12 Dec 2006
    5,841
    Thanks Received:
    400
    Country:
  4. Wontdothatagain
    12 Jun 2008
    404
    Thanks Received:
    35
    Dorset
    Country:
    • Thanks Thanks x 1
  5. holmslaw
    12 Dec 2006
    5,841
    Thanks Received:
    400
    Country:
  6. doni
    10 Apr 2005
    87
    Thanks Received:
    4
    Country:
    "Unlike conventional clamp meters, the Megger MMC850 Multi-core Clamp Meter has a complex array of planer magnetic sensor coils to calculate the current flowing in the conductors of multicore cables with either 2 cores or 3 cores, and in either flat or round section cable, up to 100 A. The convenience and potential time saving from using the Megger Multi-Core Clamp is considerable."
  7. fireman22
    18 Mar 2005
    796
    Thanks Received:
    10
    Country:
    must admit i havent seen one of these, does anyone know how accurate the reading it gives is?
  8. martinxxxxxx
    24 Oct 2009
    1,032
    Thanks Received:
    58
    Hampshire
    Country:
    I don't think Megger would lie so consult the MI online, someone might do it for you.
  9. cumbriahandyman
    23 Nov 2010
    1,256
    Thanks Received:
    43
    Country:
    Not sure of the accuracy but at up to £145 each + £25 for a calibration cert, they are not for the DIYer.
  10. JohnW2
    28 Jan 2011
    30,576
    Thanks Received:
    1,947
    Buckinghamshire
    Country:
    They claim that it has a resolution of 0.1A and an accuracy of 5% + 10d, such that it is 'reasonable' for currents in the range 2A - 100A, but pretty useless for currents <2A.
    I've seen talk of these before, and must say that I'm rather intrigued by the described technology, and rather surprised that it can give anything approaching accurate results; at the least, I would have expected it to be very orientation-sensitive.
    Kind Regards, John
  11. fireman22
    18 Mar 2005
    796
    Thanks Received:
    10
    Country:
    i wasnt saying megger would lie i just meant how accurate is reading as the jaws have a centralising bit and wondered how critical it would be to have a true reading on a flat twin & earth cable, has anyone used it?
  12. RF Lighting
    31 Mar 2006
    18,917
    Thanks Received:
    1,183
    Leeds
    Country:
    Just knocked this together in my workshop
    [​IMG]
    :D
    • Thanks Thanks x 2
  13. martinxxxxxx
    24 Oct 2009
    1,032
    Thanks Received:
    58
    Hampshire
    Country:
    That is brilliant, thanks for going to the trouble and to think I couldn't even be bothered to do a google for the MI.
    I have a question are all of the instuments "in calibration"? Oh and I can't read the left hand one. :oops:
    Thanks Martin
    PS we'll have to think of more things for you to knock up and photo - your experiments are one of the best things about this forum - that someone is prepared to do something practical to add to a discussion. Well Done
  14. EFLImpudence
    7 Jul 2010
    18,034
    Thanks Received:
    1,973
    Retired to:
    Country:
    Portugal
    It says 01.9 as well.
  15. RF Lighting
    31 Mar 2006
    18,917
    Thanks Received:
    1,183
    Leeds
    Country:
    Unfortunately none of the instruments are calibration. I have never needed a clamp meter that is bang on accurate, so con't justify £40 a year on it.
    The load was a 500W halogen lamp, so the readings are possibly a little on the low side, but they are near enough.
    The meter on the left says 1.9A too. It's my meter I use at work and has got quite sratched so is a little difficult to read in the picture.
Loading...
Share This Page
