Aurora make the M10/M7 which are 10 and 7 watts respectively (where did they get the names?!) come with plug and play ends. They also have insulation caps so you can cover them with insulation.How do these work? Do they radiate heat out the front? (Like PAR16s might do?)
Any links to dimmable products that can work?
Also will the fire hood help keep in the insulation from being a problem assuming I use good quality bulbs?
Or, I think they still make standard fittings that can have the insulation caps fitted and Enlite (another Aurora brand) make brilliant LED GU10 lamps
