I'm installing a direct 42x18 cylinder for a friend with a 3kW 27" immersion heater mounted in the top of the cyl.
Will this be enough to heat the majority of the cylinder or will i end up with stratification and not enough hot? Just two elederly people live in the house.
Also, the feed is 28mm and the DHW draw off is 22mm, so do i just need the right size of cylinder union for each, then make them in with Boss / hemp, then make up the pipework connections?
Any help would be greatly appreciated.
Cheers,
Pete
Cheers,
Pete
