i have got to replace the diverta valve its a 3 way in the airing cubard there are 2 gate valves in there if i turn them off will i still have to drain the system also can i use the sam ferals so just a straight swap any help woild be great thanks guys
Post a picture of all the relevant pipes and valves. Normally, you would have to at least partially drain down to change motorised valves, although there are other methods, but for a diyer not suitable.
Yes it is possible to reuse the existing compression nuts and olives if they are the same thread rate. Make of valve?
