Do all mono base kitchen mixers have a standard base size?
If the hole's too small, make it bigger. If the hole's too large you may be knackered, you could get a base plate made up for it out of stainless steel if you can find somewhere to do it
Cheers mate probably won't get back to this till next weekend but thanks for talking me through it :)
The minimum size is 30mm. The maximum is 45mm.
Yes, this size is generally standard.
Regards
Whoop! Whoop! Reckon that'll fit no probs. The current base is 5cm and new is 5.5cm, pretty sure the old one won't have had less that a 2.5mm lip :)
Just to round up, after I sorted out the mess from the pro kitchen installer I found behind the sink, the tap works great on cold, so long as no one else on the street is using any water ;)
The diffuser never works on hot - nowhere near - but its great when it does on cold :D
