Ive just built a dividing wall in my workshop underneath a mezz floor. Can I just tie it in with metal brackets to the mezz floor or do I need some kind of piers?
The mezz floor? Or the floor the wall is sat on? It seemed a bit wobbly when I was putting the top couple of courses in. The wall is about 2.1m high, 100mm wide blocks.
Thanks Woody. I think i'll add 2 brackets to each of the longer walls and 1 brackets to the small two block wide wall. The mezz floor rsj's do rest on top of the wall with a block paving brick used as a type of pad stone. Eventually i'll have partitions coming off each side of this wall which will support it some more.
