me thinks you missed my point!! surely if water is 50" from electric meter and the gas is 25' away but in the same direction then the single cable can still serve both
Because the bond should be made within 600mm of the service entering the building but after the stop tap/ gas meter. So ideally they need to be near each other. In the case that the service are in the same directional route, it would be okay but if they are in different directions, you would use two, to save on material costs.
