Door replacement
19 Aug 2010
Luton
I've got a back door and an o/s loo (barn-type) door that need replacing. The door frames are damaged too and will probably need replacing rather than repairing.
Should I go for hardwood or UPVC for the back door and how much should the job cost (supply & fit)?
In the main one uses a metal framed UPVC door as it seals better, there is a limit to the glass, over some % glass it needs some form of registration, think 50%? I would not attempt DIY for a door, they are heavy, and so not a one man job, but this house is protected from high wind, and the one remaining wooden door does not cause much of a draft, but last house having UPVC clad doors reduced the drafts so much likely paying for them selves is lower heating costs.
So much depends on where you live.
You go for the door style and material you like, and can afford. Also, composite doors are available - uPVC are so 1980s.
Consider on-going maintenance costs and security.
Just changed an old wooden outdoor toilet door for a upvc door.
Choosing between hardwood and UPVC for a back door depends on your preferences and the specific needs of your home. Hardwood offers a classic, natural look and can be more aesthetically pleasing, but it might require more maintenance over time. UPVC, on the other hand, is low-maintenance and durable but might not have the same visual appeal as hardwood.
As for the cost, it can vary based on the quality of the materials, the size of the door, and the complexity of the installation. Generally, UPVC tends to be more cost-effective upfront compared to hardwood, which might have a higher initial cost but potentially lower maintenance expenses in the long run. To get an accurate estimate, it's best to consult with local suppliers or professional door replacement service providers who can assess your specific requirements and provide you with a detailed quote for supply and installation.
