Dot and dab plasterboard
11 Sep 2014
Surrey
Hello. I am about to make an order for dot and dabbing my extension .
The plasterboard will be going on to thermalite blocks. I've watched a few videos- a few have put pva over the blocks first? Would you advise this? If so what ratio to water?
Secondly would you use square edge plasterboard or tapered edge?
Many thanks
Do you plan on plastering it afterwards or tape and fill the joints (dry lining)?
Thanks Garyo .
Would you advise to pva the wall first? I also read you should leave a gap of 2 mm between boards?
Just dampen the wall.
I'm not a fan of the PVA with everything diet.
