double pole 1 way switch with neon.. how to wire up
26 Mar 2007
Lancashire
Hi.. i was on before and have now bought a double pole one way switch with neon ceiling pull switch to run a fan in the loo.. so i have all these wires.. Balak, Blue and an earth, then Red, Blue, yellow and an earth.. can any one help on how to wire it all together .. cheers gazza
Is the fan the type with the timer? if so one of the wires will be a permanent live supply for the timer, the other live will be from the light switch/pull cord.
Because people might use different colours you must first identify which one is which. For this purpose you will need a meter and/or a continuity
tester.
