Drylining chimney & fireplace
28 Sep 2013
Belfast
Hi All.
An elderly relative of mine moved into a property a few months ago. The property has an open fire which they intend to use this winter. The walls above and around the chimney (and the rest of the property) are drylined - dot and dab. Notably the fire had never been used by the previous occupier.
I was asked if i could clean the chimney for them as i have the necessary equipment but when i looked up the chimney i noticed that the drylining of the chimney breast extended down behind the fire surround and the cast iron insert.
There is about a 10mm gap between the drylinng and the blockwork as it has been dot and dabbed on, however this gap has not been sealed in anyway which didnt seem right to me. I would have thought that gases from the open fire could potentially enter the gap behind the plasterboard and travel into the floor void and the bedrooms above resulting in say carbon monoxide poisioning.
Im not too familair with drylining however this just didnt seem right to me. Any one more knowledgeable have any thoughts on this. Appreciate any opinions.
Thanks in advance.
