What is circ pump? It had a fault al08 just before this happened, I think the filter was blocked, so I cleaned and rinsed it all out, the machine is emptying, I also put a couple of bowl fulls of hot water in it to flush it out, then put it on a program - that is when the error code al10 came up
fo8 is heater related when you put the dishwasher on does it fill with water and spray around ,then al10 appears.if so heater is open circuit ,if it dont spray water then its circulation pump circ
