With considerable difficulty. However, this discussion is about BS7671 regulations relating to main bonding, which are silent on that issue, and essentially only talk about 'explicit' extraneous-c-ps- primarily metal pipes and structural metal which enter the interior of the building.How does one "bond" a damp and therefore electrically conductive stone wall and/or floor to the internal CPC of a building ?
Agreed. Even accepting the decision to attach the bonding outside, the cable could have gone through the wall nearby, and found its way to the MET within the building - so one imagines that the only reason it has been left as an outdoor eyesore is based on considerations of 'convenience' (including disruption of decoration etc.).There are two initial choices. Run it outside or inside. I suspect it was done externally so as to avoid damaging the decoration inside.
Indeed.So that leaves burial, assuming there are no gas, water or waste pipes or electrical cables in the way.
It's far from rare.Even accepting the decision to attach the bonding outside,
No doubt it does when nearer the MET. Indeed, it must do.the cable could have gone through the wall nearby, and found its way to the MET within the building
Yes, I would say the conduit is far more of an eyesore than would be the cable clipped to the wall and painted.- so one imagines that the only reason it has been left as an outdoor eyesore is based on considerations of 'convenience' (including disruption of decoration etc.).
Indeed not.It's far from rare.
Agreed. Even not painted would probably be better than the white conduit. ... or, as has been said, buried.Yes, I would say the conduit is far more of an eyesore than would be the cable clipped to the wall and painted.
I'm not really making an issue of it, and nor have I discovered anything new.I am not sure why you are making an issue of it. I keep getting the impression you have made another discovery that no one has ever thought of before.
It would be aesthetically reasonable if the cable run across the door remained in white conduit (against the white doorstep, but with the rest buried - it's the white conduit against the brick wall (and grass) which looks so awful.And which tradesmen would bury this cable as the part below my door is concrete so it would need drilling
Given that it's unnecessary in the first place, I don't think whether or not it is UV-resistant is of the slightest relevance. However, it would certainly look better if not white (almost any other colour would probably be better!) - indeed, even a bit better when discoloured as a result of exposure to UV!It should be painted anyway as white plastic conduit is not UV resistant.
