earthing conundrum
12 Sep 2004
As part of my bungalow renovation, I am splitting what was a large extension utility room into two
There will be a utility room and a bathroom seperated by a plasterboard wall with a door in it
In the utility room will be the new combi boiler, washing machine and tumble drier
The gas and mains water enter the building in this room so will be seperately earthed back to the CU and the boiler will be cross bonded. The controls for the bathroom extractor fan and waterproof low voltage lights will also be in the utility room
What should I do with the bathroom earthing as it was originally part of the same extension and is as I said, only seperated by a plasterboard wall.
Is it really neccesary / legally required ?
If so, my understanding is that all pipes cold hot and central heating should be connected together and one earth cable taken to the nearest
lighting earth which will be outside of the plasterboard wall. Is this correct ?
30 views - no answers
did I answer the question myself ?
or is there a fatal flaw with my thought process ?
Yes it is really necessary, no it is not legally required
lighting earth
Correct.
Do you not have a ceiling light, wall lights or shaver socket in this room? If you do, connect the bonding to the earth terminal for one of these.
Michael
thanks fubar
will be using 12v lighting overhead only
cannot abide electric shavers
I always wet shave
its not too difficult to run the earth outside of the stud wall
it seems a bit belts and braces but there you go - I am even running a shower off the combi - am putting an electric one in the new en suite
the only voltage in the bathroom will be 12V for the lights
Shaver sockets often used for rechargeable toothbrushes.
Interesting question, should pipework in a bathroom which has no electricity still be bonded? Possibly, if the reasoning is to prevent shocks should the pipe become live outside the bathroom. if there is no earthed electrical equipment in the room, then logically it is not possible to connect it to the overall supplementary bonding. 12V light fittings would presumably not be earthed...as this would reduce their safety.
The main purpose of supplimentary bonding is to ensure that all exposed conductive parts in a bathroom are at the same potential, so you can't get a shock from touching two different parts at the same time. This you should do.
I agree regarding bonding to your ELV light fittings.
It is debatable whether it is safer to connect your supplimentary bonding to the cpc of a circuit outside the bathroom or safer to not connect your supplimentary bonding to a cpc. I'd probably opt for the later but make sure that the bonding elsewhere is up to scratch.
Michael
it is interesting because there is no earth bonding that I have seen in our bathroom (which has no electricity apart from recessed lighting). I wonder if I should install some quickly as the kitchen underneath is undergoing some work and an earth back to the CU (or incoming cold main is on the way too) would be easy to run at this moment in time.
