Earthing Lighting Circuit
I plan to run it surface. I am never going to put a socket there. But i see what you mean. I might need it in the future. So If i use 10mm that should be ok then!? I plan to draw the supply from the hse (using the 10mm) using a 6A breaker. I will have a 2way consumer unit in the shed, but since i only need the lights now - one 6A mcb will be used to connect the light circuit. If i need the sockets in the future I can run them off the second 16A mcb. What do you guys think?
Cheers!
