Hi all
History on this problem. Few days back I noted low bar on the pressure gauge so decided to do the standard fix of opening the refill taps. Unlike previous times I did not hear the running water and the bar did not improve. I decided to leave this look at later. When I next looked at the bar it was high so I assumed I had in fact let water in. I later noted that it kept increasing until it was way off the gauge. On looking outside some minor water was coming from the pipe at the rear of the house though not a huge amount. I did some web searching and it seemed the most likely issue common on this model is the taps no longer work after a while and the water is not fully turned off so pressure is coming in from the mains supply. Having noticed that inside the taps is a Phillips screw head I thought turning this would perform the same operation as turning the tap. So I turned the one on the left right (Right is tight or off as I thought) This did tighten but eventually produced the running/filling water sound so I went back left. This produced a large water hammer sound which originated from I dont know where but sounded like the pipes. Now I have no hot water and I dont mean the water is cold there is literally only a dribble coming from any source of hot water, taps, shower. It does not appear to get hot either. Heating is working fine, no error codes, pressure is dropping. Have waited an hour no still nothing coming from hot taps :/
Any ideas? Cheers
Any ideas? Cheers
