ELECTRIC UNDERFLOOR HEATING CONNECTED TO THE FUSE BOARD
1 Jan 2008
West Midlands
Guys
i am fitting ELECTRIC UNDERFLOOR HEATING in 2 bathrooms,
rather than connecting to a fused spur am i ok to connect both bathrooms
directly from the fuseboard as i have a spare fuse (new crabtree splitload
consumer unit fitted in January),
if so what AMP size RCB is required,
al
What's an RCB? Do you mean RCD, or MCB (now known as a CB).
You'll need both for this job. So maybe an RCBO might be the best way forward?
Oh yes, this is notifiable work because: Its a new circuit AND its work in a bathroom.
You must notify your LABC before you start work, and pay them money.
Does it mention the need for DP switching?
Does it mention a maximum fuse size?
Ring the mfr tomorrow & ask them if what you propose is acceptable to them.
Yes, sorry typo
securespark
sounds like good advice, i will do this,
thanks all for your advise
cheers al
Guys
manufacturer recommends (ideally) a separate radial circuit coming off a 16amp RCD into a 13amp fused double pole switch,
al
