Electrical requirements for a power shower
17 Sep 2004
When installing a power shower, one which has an integral pump but no heating element, what are the electrical requirements?
Does it need:
1. A ceiling switch like an electically heated shower?
OR
2. A fused spur off the 30 Amp ring main?
OR
3. A dedicated switched connection back to the consumer unit?
OR
4. Something else?
Any help would be appreciated.
Regards
Graham
A fused spur off the ring, fused at 3A I would expect, with an integeral 30ma rcd if the ring is not rcd protected
Andy,
Sorry for the delay in responding, but just a note to say thanks very much.
You need to have the FCU easily and readily accessible. I installed mine next to the switch for my immersion heater which is installed right next to my bathroom as this seems most logical to me, plus mine is a separate pump so is in the same cupboard.
Sticking it in the loft above the bathroom isn't allowed, as far as I am aware. I mention that one as that would have been the easiest place to install mine due to the cable runs. But, it would have meant to isolate the pump you would need to climb up into the loft. Not exactly desirable when wet and naked!
