Hello!
I'm planning on running electrics to my shed where I'm in the process of installing some decking. I intend to run 12v decking lights and may be a radio from this, however I would appreciate your ideas on whether I can run a security PIR flood light from this as well?
My plan is to run some flex (in conduit) from an outdoor socket mounted on the house. This is from B&Q kit with the other end plugged into a socket in the house (there is an RCD plug on this end). The other end will, as I said run in conduit attached to the outside of the house then end at a weatherproof box. From here I plan to run SWA initially along the fence line (mounted on fence) but later buried (when I renew the fence). At the end of this run I plan on putting another weather proof box and using flex inside the shed to a socket into which I will connect a weather box containing a four way socket into which the lights etc will plug.
Further to this, I am think of buying a photoelectric switch to attach between the four way extension and the socket inside that will allow the lights to automatically turn on for a few hours at dusk.
I'm thinking that as this is not a permanent fixture, and not hard wired into the CU, this should be OK with part p? What are your opinions on this and what type of SWA do you think I should go with, in terms of 2 or 3 core and 1.5 or 2.5mm cores?
Are there any websites that give good instructions of terminating SWA, I've had a look around and found a few but there are always those hidden gems that don't get shown in the first few pages of Google results!!
Thanks all in advance for reading,
Gaz
Gaz
