Electro Oil Inter 10 oil burner
12 Jun 2008
Suffolk
Can I still get a replacement motor for this burner. It's on a Trianco Redfyre Centrajet 13/17 wall hung boiler. The motor details indicated in the manual indicate a 90W, start 2750rpm.
Any other suggestions also welcome.
I've put on a new capacitor thinking that was the problem in the first instance. but that didn't solve the problem. I've removed the motor from the burner tried to rotate the motor and fan by hand and it won't spin freely. Perhaps the bearings are shot!
Yes. Motor and fan alone removed from the burner. Normally it would spin freely but this time there is resistance. That's why I've come to that conclusion.
Logical! I think you can replace the bearings on most of these motors.
Here is one supplier. You need 6202 2Z for this motor. Replace both as you have the motor in bits. Split the motor carefully to avoid damaging the wires, and use some form of PRESS to get the new bearings on the shaft, ONLY APPLYING FORCE TO THE CENTRE RING.
