hi thanks for repleying, if you spin the motor by hand and switch power on at the same time it runs fine but wont start by its self so theres power getting to motor its as thow there isnt enough power to kick it in,
Might just need the run capacitor replacing. Check if there is any leaking here.
Otherwise new motor needed then.
You'll also need to have it set up by an oil engineer as a new motor
will most likely affect the pressure and therefore need a flue gas analyser.
