Hi
I did my homework and thought it will very easy job. Simply because the wiring for my salus ep200 is exactly as wiring for Wiser 2 Channel programmer. Both are attached.
Yesterday finally found some time to take ep200 off and install wiser on. Same time, I disconnected my old room RTS1 thermostat. New programmer powered up as expected. I had green light on water and heating. I went through creating account, fine no issue here. The only problem is that heating and hot water did not work. Basically when I increased temp. on wiser room thermostat, (call for heat) boiler did not fire up.
This is my current wiring. It is as required by wiser programmer.
This is my RTS1 wiring.
The yellow cable is call for heat! I should bridge this wire somewhere else? Without this cable wiser will not be able to control heat. Also on the programmer side there is no yellow cable. So where it is going to?
Diagram for EP200
Diagram for 2 channel wiser
I would be grateful for any help.
Diagram for EP200
