Euro cylinder locks
17 Apr 2009
Surrey
Hi everyone.
I have a quick question for the floor...
My father has a upvc porch door with a eurocylinder lock on it. The handle does not turn on outside but does on inside. Obviously this is to stop people just walking into the porch area. I would like this type of lock on my upvc door but cannot figure how its done or do I have to buy a new eurocylinder lock that does this because my door opens from both sides unless locked each time.
Any suggestions please would be welcome?.
You would need to have a locking mechanism with 2 spindle holes, Take off your handles to see if there is a 2nd spindle hole just above or below the one your handle is using.
Assuming you do have 2 holes you would only need the correct handle and a split spindle. If you don't you would need a whole new locking mech.
Personally I advise against them, My old company used to fit them to every door and I would have to go and drill out a lock at least once a week where someone had locked themselves out. Come to think of it it was probably a good little money maker for them :rolleyes:
2 ways of achieving this but both need the correct mechanism
Gazmans suggestion or 'Split follower'
The follower is the square hole in the mechanism that the spindle passes through, if the follower is split down the middle i.e. the outer half turns independantly of the inner then by using a split spindle both handles will work independantly of each other
And as Gazman says you can easily be locked out with a split system, effectively just like a yale lock set up, if your used to pulling your pvc door to on the latch as you pop out to the bin or if the wind slams it shut then your locked out........unless you have the keys with you!
