- Joined
- 2 Oct 2010
- Messages
- 3,624
- Reaction score
- 667
- Country
Nickso has already explained, but the OP has blinkers on it seems.
Mr. W.
Mr. W.
Hi, Just turned all 13 rads on to max .will come backto you when they heat up.What expansion do you reckon from the 1.5 cold to max ?cheersUnless all rads are open you are not seeing the true full expansion of the system, most of the water in the syatem is still cold.Hi, How do you work that out, theres still 0.5 bar spare.I.ve only got 4 of 13 rads going at present.please explain FLAT. To me that means no air in?Its flat. That is unless your heating system is so big, you need a remote vessel fitting aswell, or your communication tube is blocked.
Mr. W.
Also to get a 1 bar bressure increase with just 4 rads you have an expansion issue. Get all rads open at full temp and watch pressue and PRV discharge. Everything you have said sugests to me PRV discharge. I am no expert but this is how it seems to me.
Hi, My most humble appologies.IT.S FLAT. Only reached 70 degrees and just touching 3 bar, ready to blow. Turned it down now. So you say I need to re-inflate exv to 1 bar. Never usually have boiler up full.I have done this before, years ago.b*****r
misterdubya beat me to it.
But you will see we are both thinking along the same lines.
Hi, Just done that. Air coming out.This would not explain water loss would it? unless membrane was perforated.??cheers all. very much appreciated.Obviously never read your posts enough.Have you pushed the shrader valve to ensure its flat and not knacked?
If its flat, follow the faq's. Remember to open the system up to the atmosphere.
Mr. W.
Hi, Actually I was contemplating a new one next year.!7 years old Vokera.Just want to get winter through.Do you recommend Gloworm?Well, open up the system & re-pressurise to 1 bar. If your problems persist you may have a bigger problem (ie a Glowworm.)
Mr. W.
Not personally, but thats another topic as all RGI's have their reasons behind their choice of decent boilers.Do you recommend Gloworm?
Thanks , I will repressurise EXV tommorrow.And re-post result. Again,Thanks allNot personally, but thats another topic as all RGI's have their reasons behind their choice of decent boilers.Do you recommend Gloworm?
You will see many discussions on this site about that.
Mr. W.
If he does this at 80degc might this not damage membrain/bladder in exp ves when it cools as the effective pressure in exp ves will increase, as the system pressure drops.
