I've fitted two sets of external lights - downlights and bulkheads, and although they are external they are in sheltered positions.
I want to control these independently from two switches in the house.
So should I (could I) add these to the existing ground floor lighting ring, or should they be off a dedicated external light circuit?
I'm not having any external wire or conduit so that is why I wondered about connecting these to the internal ring. Else I will need to run a cable through the house from the CU
I might end up using dimmer switches for these lights, so would a loop in the switch be too crowded, or am I better off looping at a junction box?
