Hi all,
New here so I hope I’ll find it useful!
I am planning on building a garden pond in the next couple of months and obviously I need a power supply for the pump etc.
I know the cable has to reinforced and buried at least 500mm with warning tape 250mm above that.
My garden is quite strange in that I have a patio then a steep ‘hill’ 2 meter(ish) then sort of levelling off(ish) I also think there is drain works under the patio leading across most of the length.
So if there is piping beneath does the armoured cable need to run beneath this or can it placed on top even if less that 500mm?
Where I lead the cable up to the supply obviously this will need to be metal conduit are there any regs as to how deep this needs to be sunk (simply 500mm to meet the cable)? Are there any height restrictions on the waterproof socket (minimum height?)
I have no spare outlets on my CU so will need a 2 way RCD CU adding? I am competent in wiring this all together but any idea of the cost (very approximate) for connecting new tails to this?
Any other points to consider?
Thanks in advance sorry it’s such a long first post hehe
