Hi Guys, just joined this forum and so here goes. I am a corgi registered engineer and have recently started to repair combis of all types and names.
So the question I want to ask is, I was called out to a worscter 28i after a contractor had fitted an outside water meter. So I automatically assummed there would be debirs on the cold inlet which was restrciting the flow switch. But after checking the boiler I found it was neither working on the hot water or heating and the customer is adamant the boiler was fine before the installation of the water meter.
So here's what happens the boiler goes to fire up, the pump starts, the fan starts, the aps makes the switch and then there is nothing no spark nothing. I put my multimeter on the 2 pins of the gas valve connection on the PCB and there was no reading. Does this indicate a fault with the PCB if there is no voltage from the PCB to the gas valve or have I missed something. There was no manual with the boiler so I was going off experience. Any help or advice would be appreciated before I buy a PCB.
Dave
Dave
