Some posts have been removed.
Thank you. So my situation is now that I have a freshly painted wall with the same cracks reappearing. Should the decorator really have known how to properly treat them? And do I get him back to treat them properly and repaint that wall?!I am a decorator...
I have worked in a number of victorian properties where the original plaster has a series of cracks on the exterior solid walls. I rake the cracks out, brush in some PVA, wipe away the excess, let it dry and then use Toupret Flex and Fill. It is similar to caulk but has tiny fibres in it to reinforce it. It shrinks back slightly overnight. The next day I face fill it with a powder based filler.
It works very well.
In 2019, I used it to fill the cracks in the exterior render on my own home. It is still crack free.
Ok, wasn’t looking for you to malign anyone, just for advice! My decorator is in his 60’s, incidentally, so has also been doing this work for a long time.I am not willing to malign your decorator- I am in my 50's. I have been around many blocks. In the old days I might done the same as him.
They opened up the day he finished though. Which makes me wonder if he should have repaired the cracks using a different method or using a different meterial, given they came straight back.
He did, as I said in my original post. He filled them then repainted the wall. But they cracked again as soon as the room heated up on a warm day, literally hours after he left on his last day of work. So I’d really like to know, if I get him back, how they should be filled properly this time so that they don’t just reappear again. Because he couldn’t have used the right method or filler.If the crack were there, whilst he was painting, then he should have taken steps to repair them.
Thank you.In that case, reasonable to invite him back to make a better repair. He should open the crack out, into a V, then use a flexible filler. Others might be able to suggest the best filler to use.
