Filling deepish hole in brick wall
ODB
28 Mar 2006
London
Hi there
I had a pipe repaired that was inset into a brick wall and as a result I have a 25cm x 15cm x 10cm deep hole with a pipe running down the middle in the kitchen.
I asked the plumber what I should fill it with and he suggested not using foam as plaster wouldn't stick to it very well. I do remember someone suggesting I use 3 parts of x and 1 part z to use it to fill the big hole (as I had some plastering bags left over) but I can't remember what the mix was.
Can anyone suggest what I should fill this deep hole with? I intend to plaster over the top of it to make good.
As always, many thanks for any help!!!
thistle bonding, thistle browning or good ole sand/cement (mortar/render).
you may have to apply in two coats or more because of slumping.
Wow! Thanks for the quick response!
I'm assuming I just mix it up with water until it's like thick porridge and just slap it in, but, you know, using several thin(ish) layers at a time?
What about that 'prompt' stuff...the quick drying cement (do they still make that?)
Good gear and it dried very quickly.
Think I've got half a bag of that Thistle stuff. If I find my camera I'll do a 'before' and 'after'!!
It's my project for the day according to the gf.
Before:
...a bit bigger than I remember it...
dampen the area with water first. fill it in layers. don't use thistle finishing plaster only bonding or browning.
haven't you created a pressure bottleneck reducing the pipe like that?
That pipe should be taped up or sleeved first....not just laid bare.
Darren
As Darren7 says, 'that pipe should be taped up or sleeved first . . .' I've just bought a house and found a hug crack in a bedroom wall. When you put your hand to it, it feels warm and I've realised it's because the central heating pipe vents up to the roof behind the wall. I haven't investigated yet, but I'd assume there's nothing to stop the heat getting into the plaster. I'll be fixing that. Easier to do now before you do your repair!
