Fitting new 5111603 PCB to suprima 50
Discussion in 'Plumbing and Central Heating' started by Kovo, 13 Feb 2006.
  1. Kovo
    13 Feb 2006
    7
    Thanks Received:
    Country:
    Hi
    After reading posts on this forum I have bit the bullet and bought a 5111603 PCB kit for my Potterton Suprima 50 boiler.
    The new PCB comes with the wiring loom attached.
    My main concern is the new pcb has a 5 terminal molex block connector for the gas valve which has one red and one black wire (with the other 3 holes free). The one currently fitted in my boiler also has the red and black wires but the remaining 3 positions are filled with one green/yellow earth wire and a white wire which loops out from terminal 2 and goes into terminal 4.
    Does the new PCB no longer need these addtional wires and therefore I can just plug the new PCB in?
    I have no problems in building PC's so have read that I should be able to replace this PCB? ie I am not a plumber / electrician. Is this task suitable or should it really be a corgi guy doing the job?
    Feedback appreciated
    Cheers
  2. corgiman
    25 Aug 2003
    10,668
    Thanks Received:
    53
    Surrey
    Country:
    nope you shouldnt the pcb controls the safety features of your boiler and according to gas safety installation and use regs 199 you must be a competent person to fit it
    sorry
    sure the others will disagree till time immemorial but thats what its says in the regs, and what CORGI
    also you have to remove the combustion chamber cover to fit this board which for you is a defo no no
  3. croydoncorgi
    6 Jun 2004
    4,024
    Thanks Received:
    338
    London
    Country:
    Agree with previous comment..
    and it would be a terrible shame to stuff up a brand new board by fitting it wrong.....
  4. Kovo
    13 Feb 2006
    7
    Thanks Received:
    Country:
    Thanks for your swift reply Corgiman.
    I certainly will not take any risks so will therefore arrange for a Corgi qualified engineer out to fit.
    The step by step instructions certainly tempted me to have a go, were it not for the problem mentioned in my original post.
    So I dont waste a call out fee, can the engineer fit this kit or have I got the wrong one?
    It seems the 5111603 kit for this boiler is a common puchase for Suprima owners!
  5. bones001
    4 Feb 2006
    105
    Thanks Received:
    Country:
    thereis a common fault with suprima boards that happens to them.you get this, when it cuts down on the boiler stat or room stat it doesnt come back on and you have to reset it all the time.
  6. corgiman
    25 Aug 2003
    10,668
    Thanks Received:
    53
    Surrey
    Country:
    nope its the right board
  7. Agile
    26 Jun 2004
    61,249
    Thanks Received:
    4,281
    London
    Country:
    I agree about the CORGI but the very sad thing is that the quality of CORGIs leaves very much to be desired in some cases.
    Today I went to a new boiler. It was a system boiler and the installer had wired its supply to the output of the controls. When there was no call for heat there was no permanent live and so the internal frost stat and pump over run were inactive.
    More STUPIDLY he removed the thermostat link "because the book said remove the link when external controls are fitted". This guy "has been fitting boilers for 20 years".
    That level of stupidity amazes me but is an every day occurance!
    Tony
  8. ChrisR
    24 Jul 2003
    23,728
    Thanks Received:
    1,194
    London
    Country:
    Have to agree. The average plumber is perfectly able to follow instructions and work through a problem even as a novice. But, alarmingly frequently, it's astonishing what one finds, done by people who should know, and do, better.
    Edit much later : the new boards are going wrong too, but they last a lot longer than some of the originals.
    Quite often when that happens there's a fault on the boiler which has caused it - which a diyer wouldn't know to look for. If you're unlucky the new board will make a click and then be scrap. New looking ones killed like that, seem to find their way onto ebay... :evil:
Loading...
Share This Page
