HI,
Like many have a Suprima boiler that needed a new PCB board.
I have brought a replacement Interpart PCB KIt 5111603.
All seemed ok except when I went to connect the power to the gas valve, it seems to be missing a white wire that is looped on the block on the original PCB wiring. In fact in the picture on the instruction for the replacement board it does show the block with a looped white wire and a central earth lead.
Is mine missing something, is this white loop wire nesecarry or should I just cut the block of from the old PCB ( resolder wires) and use that.
Dont really want start boiler withot checking first.
