I had a full rewire and the electrician removed the MR16 12V IP65 downlights from the bathroom and replaced them with fireproof 240V ones. The problem is these, although LEDs, they are hard wired to a junction box in the loft and have no replacement bulbs.
So does that mean that when the LEDs go( and I have seen LEDs failing ) I have to get an electrician to replace the fittings!
I guess I opened one up and I discovered only 75mm height below the ceiling as there is a joist right underneath...
Any idea where I can get low depth fireproof downlights for the bathroom with either MR16 12V bulbs or 220 GU10s?
