Flickering lights
JohnD said:
You should get some CFLs (Energy Saving Lamps). Apart from saving you money on electricity, they last for years and are tolerant of supply voltage fluctuations.
still this.
I would lean towards John here. ( :eek: )
Even with diversity applied, you have a load in excess of 2kW.
Either follow John's idea, or be prepared to split the existing circuit into three.
As I said I still have to put lights in my loft which will be more spot lights so I dont really want to add them to my already full up lighting circuit.
Is it possible to add them to the socket circuit with a fused spur?
Thanks.
It is possible so long as a 3A fuse is used but it isn't good practice and you are better off having the lighting circuit split (upstairs/downstairs).
Davy
There must be a reason why you don't want to fit CFLs. What is this reason?
I am thinking of doing the following then please advise if possible
Replace some of my bulbs with energy saving ones
Replace the 3 light spot in the bathroom with a standard light fitting 1 bulb
Downsize the outside lights with smaller bulbs
Put the loft lights onto the seperate loft ring main (Fused spur)
Thanks.
How many is some? With the savings made by changing it makes sense to replace ALL lamps with CFLs.
There's no need to change the fitting if you replace the lamps with CFL's. That alone will drastically reduce loading on the entire circuit.
If they are security lights with PIR's most wont accept energy saving lamps but depending on how many you have and how many CFLs you install you might not need to bother.
If you reduce the circuit loading sufficiently you could easily accommodate the loft lights into your lighting circuit.
Davy
Not sure what the wattage the bulbs where for the 2 outside lights but I was thinking of putt less wattage in them both to help.
What are the implications of having too many lights on one circuit? Will it keep tripping?
All the lights wont be on at the same time (Have a word with the wife) but I need to make a calculation so I can make a decision on whether or not to fuse spur the loft lights.
It's not a problem having lots of light fittings as long as the total wattage of the lamps fitted don't exceed the MCB/fuse rating.
Diversity for lighting circuits is 66% so work out the total by adding up the wattage of every lamp and then work out 66% of that. If it is more than the fuse/MCB rating you have a problem - a problem that is easily solved by replacing as many lamps as possible with CFLs.
Davy
Thanks for your replys and patience so far.
I will add up my wattage tonight.
Thanks,
Conrad.
Sorry JohnD I missed your reply.
I will look into the CFL's but they doo seem a bit expensive. I know they will save money in the long run. I think I may replace when they go with CFL's.
On the link that was provided it said the bulb is 20mm longer than normal too.
You can buy 100/200/300W standard length linear tungs/hal tubes for floodlights.
why dont he change the floodlights to low energy ones?. i have all low energy bulbs now in house even r50 spots low energy tescos have most low enrgy bulbs half price they were bargains got candle bulbs for under 2 pound each
