D
DeletedUser
I have a Worcester C1 combi boiler, ever since I moved into the house back in April I have been having problems with the hot water. So far I have had the thermistor changed, the water valve changed and now the board changed.
The problem was keeping a constant supply of hot water, on occasions when I turn on the kitchen tap the water will get very hot but then all of a sudden cool down. After having called out three engineers I gave in and called Worcester, they came out today and thought it was the board. They replaced it but it still didn't fix the problem and are now saying there is nothing wrong with the boiler. My main problem is that I had a new mixer shower fitted a few weeks ago and so far have been unable to use it as it the water won't get hot enough, although the hot water coming through the taps is not so bad, its just about warm enough for a bath.
The Worcester engineer has suggested that something must be wrong elsewhere and I may need to lift all the floorboards up to trace the pipes. He suggested turning off the valve under the boiler and said this should stop any water coming out the hot tap, I have turned it off but the water still comes from the hot tap. I am getting pretty desperate now to actually finding out what the problem is, nobody seems to be able to tell me!! Any ideas will be gratefully received. Thanks
