GTM & TGM?Softus said:BTW, opinions from joe-90, GTM and TGM do not count on this subject.
You might enjoy it...ban-all-sheds said:Ah - I never go there.
Gits. And gas engineers are pompous gits.ban-all-sheds said:If electricians are sparks, and carpenters are chippies, what are plumbers?
I think you're the only one who's amused by this. The rest of us are bemused.breezer said:no i am not big spark in disguise, but i still say you are wrong, and the lecturer is technicaly right.
still if i kept you amused fine.
OK, let's get this over with, if we really have to...breezer said:all i can suggest is assume we are not talking about electricity, and say plumbing.
I shall assume that your analogy includes a pump, rather than relying on convection.breezer said:usinig pipes for the cables and a rad for the lamp.
use a directional flow meter, instead of an electical meter and see what happens.
When you reverse the direction of the pumped flow. Or, if there is no pump, then when gravity reverses its polarity.breezer said:the question is then when does the flow become the return
Amazing - you're right - when I forget what I know it all makes perfect sense! So does the penguin in my fridge! I shall use this technique whenever I find myself talking absolute pants - I'll just tell the other peson to forget everything they know and reeeeelly open their mind.breezer said:I will admit it does not seem right, but look at it again with a really open mind, forget what you know and read it again.
It's not a question of being open-minded - the lecturer is only "technically right" in such a pedantic and narrow way that as I said - nobody with any common sense, or desire to communicate properly with someone would ever call that black wire anything other than neutral.breezer said:no i am not big spark in disguise, but i still say you are wrong, and the lecturer is technicaly right.
How could he do that, if there is no neutral?In [url]//www.diynot.com/forums/viewtopic.php?p=48998#48998[/url] breezer said:you either made the diagram wrong or didn't follow it
you have put the switch ACROSS the live and neutral
In [url]//www.diynot.com/forums/viewtopic.php?p=46125#46125[/url] Albert said:Would it be wrong to say that the black (neutral) should be marked with a red sleeve?
No it wouldn't - it would be a live.and breezer said:albert, yes it would be wrong, since in this case it is a neutral.
What neutral?In [url]//www.diynot.com/forums/viewtopic.php?p=32967#32967[/url] breezer said:you can not do as you suggest because with a timed fan it needs a switched live to make it work, agreed?
the switched live comes from the lighting circuit, agreed?
so how are you going to isolate the fan supply with a fcu that at best can only isolate 2 poles, , if you use it to isolate the lives you are not isolating it as the neutral is still connected, so if yo isolate the neytral which live do you isolate, and if you dont you can back feed into the lights so they will work when off and vice versa.
No they're not - they are live, surely?In [url]//www.diynot.com/forums/viewtopic.php?p=29751#29751[/url] breezer said:as its a timed fan, you should connect it direct to the light supply
the timed wire should go to the lamp live
normally it would be as follows
3 reds in middle of rose are always live (add fan live here)
2 blacks to one side of rose are neutral
You may not have spotted the button that looks like this:bobmunk666 said:convention should I say, a few pints at dinner.
now here is the interesting bit
(the lamp is sitting above the switch, the supply connections are below the switch, sorry i didn't mention it earlier)
so the top black wire from the switch goes to the lamp, the bottom wire from the switch goes to the supply
you connect your red meter lead to the bottom switch terminal
(remember the meter black lead is still connected to the neutral supply)
your meter will show 0v (no potential difference between neutral and neutral)
[/quote]bobmunk666 said:Does a switch not just switch in or out a connection (load) between the rails and the only difference being on which side of the load the switch is
Breezernow here is the interesting bit
The same argument would apply for the same situation on the live side. connecting a meter across the same rail will always give 0v
ban-all-sheds said:How did that get resolved?andy said:he once tried to tell us that is physically impossibly for a light to work if the switch goes in the neutral instead of live...
breezer said:you have not quoted what he actualy said.
